Dual Relay Module T2
I’m trying to use this Module for a lift master to open my main gate have any of you guys use this Module for it… the gate is using a car battery and a solar panel as a power source… would this module drain the battery out because it will be running constantly or it will only run when use?!
Hello @levo912
The Aqara T2 relay requires constant power supply to operate, it will drain the battery, but how quickly this happens needs to be checked.
