Hi everyone, I hope you’re all doing well! I wanted to share a recent project I worked on with my smart home setup, which involved creating a dynamic automation trigger for my lights. I’ve been using a binary sensor to detect motion in my hallway, and I wanted to automate the lights in such a way that they stay on for a variable amount of time depending on certain conditions. This has been a fun challenge, and I thought I’d walk through my process in case it helps anyone else.
First, I set up the basic automation using the binary sensor for motion detection. The initial trigger was straightforward, but I wanted to take it a step further by making the ‘for’ duration dynamic. After some research, I discovered that using a template to reference a variable or sensor value could achieve this. For example, if I have a sensor that detects the time of day or the number of people in the room, I can adjust the ‘for’ duration accordingly. This means the lights could stay on longer during the day or when more people are present, which is both convenient and energy-efficient.
I also wanted to share a tip related to smart scales. I recently came across a Wyze smart scale, and while it’s been a great addition, I encountered an issue where the scale would upload data from multiple users to my phone. This was quite frustrating, especially when it disrupted my weight tracking graphs. After some troubleshooting, I found that resetting the scale and ensuring each user has their own account helped mitigate the problem. It’s still not perfect, but it’s a step in the right direction. I’m curious if others have faced similar issues or have found a more seamless solution.
Another thing I’ve been experimenting with is integrating different smart home devices from various brands. It’s amazing how much you can achieve by combining devices, but it does require some trial and error. For instance, I’ve been using a combination of Govee lights and a Wyze hub to create a more responsive lighting system. The key has been to test each integration thoroughly and adjust settings as needed.
I’d love to hear from others who have tackled similar projects or have advice on optimizing smart home setups. Whether it’s about dynamic automation triggers, managing smart scale data, or integrating multiple brands, your insights are invaluable!
Cheers,
