Hi everyone, I recently dove into customizing my Habpanel interface and thought I’d share my journey in case it helps someone else. I wanted to make my door icons more visually prominent by changing their color based on their state—green for closed and red for open. It was a bit of a learning curve, but I managed to get it working smoothly!
The Goal:
I wanted my door icons to display in green when closed and switch to red when open. This would make it immediately clear at a glance whether my doors were secure or not.
The Challenge:
Initially, I tried modifying the SVG files for the door icons, changing the color in each state. I placed these modified icons in the appropriate folder, but Habpanel didn’t pick up the changes. I was a bit puzzled and worried that maybe custom colors weren’t supported.
The Solution:
After some research and trial and error, I discovered that while direct SVG modifications might not always work as expected, there’s a reliable workaround using icon themes and dynamic icons within Habpanel. Here’s how I did it:
Icon Themes:
- I created two separate icon themes: one for the closed state and one for the open state. Each theme included the door icon in the desired color.
- To do this, I navigated to the Configuration section in Habpanel and selected Icon Themes. From there, I added new themes and uploaded my colored SVG icons.
Dynamic Icons:
- Next, I set up dynamic icons for each door sensor. This involved creating rules that would automatically switch the icon theme based on the door’s state.
- For example, when the door is closed, the rule triggers the green icon theme, and when it’s open, it switches to red.
Testing and Fine-Tuning:
- After setting everything up, I tested each door sensor to ensure the icons changed colors correctly. It worked perfectly, and the visual feedback was exactly what I was aiming for!
Tips for Success:
- Backup Your Work: Always keep backups of your original icon files before making modifications. This ensures you can easily revert if something doesn’t go as planned.
- Use SVG Files: SVG icons are ideal for this kind of customization because they’re scalable and support color changes without loss of quality.
- Leverage Habpanel’s Features: Don’t shy away from exploring all the settings and features within Habpanel. The icon themes and dynamic icons are powerful tools that can really enhance your interface.
Final Thoughts:
Customizing my Habpanel interface has made my smart home setup even more user-friendly. The color-coded door icons provide a quick and clear overview, which is especially useful when I’m monitoring my home from a distance. I’m thrilled with how it turned out and hope this guide helps others achieve similar results!
Happy customizing everyone! ![]()
