Dynamic Lighting Color Changes with Soil Moisture Sensors
Hello everyone, I’ve been exploring how to integrate my Misol soil moisture sensors with dynamic lighting to create a visually appealing and functional setup. My goal was to have the lights change color based on the moisture levels in my plants, transitioning from green to yellow and finally to red as the soil dries out. I thought this could be a fun and practical way to monitor plant health while adding some ambiance to my space.
I started by connecting my Misol sensors to Home Assistant and setting up the necessary entities. Then, I delved into the automation section to create rules that would adjust the light colors. The challenge was figuring out how to map the moisture percentage to specific color values. After some research, I discovered that using RGB values and conditional statements in my automations was the key.
Here’s a brief overview of what I did:
  1. Sensor Setup: I ensured my Misol sensors were correctly paired and providing accurate moisture readings.
  2. Color Mapping: I decided on three thresholds—70%, 40%, and below 40%—to trigger green, yellow, and red colors, respectively.
  3. Automation Rules: I created automations in Home Assistant that check the moisture level and adjust the light’s RGB values accordingly.
  4. Testing: I tested each threshold to ensure the colors changed smoothly and consistently.
The result is a system that not only alerts me when my plants need water but also adds a dynamic element to my home’s lighting. It’s been a rewarding project, and I’m excited to see how others might expand on this idea. If anyone has tips or alternative approaches, I’d love to hear them! :seedling::bulb:
