Hi. I have a question regarding one of my E1 radiator thermostat. The black knob that operates the valve has fallen off. How could I put it back? It has to be pushed (pressed) or screwed in?
@ESSCO4355 Hi there! Thanks for reaching out with your question about the Aqara Radiator Thermostat E1. It can be a bit confusing when parts come loose, but let’s clear that up.
The black knob you are referring to is actually the main body of the thermostat itself, which houses the electronics and the internal pushrod mechanism. It is not a simple snap-on cover or a screw-on dial in the traditional sense.
To reattach it, you need to screw it in. Here is how it works:
- Ensure the Pushrod is Retracted: Before attaching the thermostat, make sure the internal pushrod (the part that turns the valve) is fully retracted. If it’s extended, the thermostat won’t fit or might damage the valve. You can usually reset this by removing the batteries for 30 seconds and reinserting them, or by powering it on and waiting for it to initialize.
- Align and Rotate: Align the thermostat’s interface nut with the radiator valve adapter (like the RA, RAV, or standard M30x1.5mm adapter)[“content_id”:3"].
- Tighten: Rotate the thermostat body clockwise until it is hand-tight. You don’t need a wrench; just tighten it firmly by hand.
Once attached, remember to perform a valve calibration by pressing the button three times consecutively. This ensures the thermostat knows the open and close limits of your specific valve.
If you find that the physical connection is stripped or the adapter is damaged, or if you continue to have trouble attaching it, it might be a hardware issue. In that case, please contact customer support for assistance.
Happy home automating
I think is not the main body of the thermostat. What is fallen down is only the little knob; the little black cilinder long about 5 mm.
@ESSCO4355 Got it, thanks for the clarification! That small black cylinder (~5 mm) sounds like the internal pushrod — the component that physically extends and retracts to open/close the valve pin. It’s a delicate mechanical part, not something designed to be user-detachable.
If it’s come loose, here’s the reality: this isn’t a field-repairable component. The pushrod is housed inside the thermostat body and interfaces directly with the motor and gearing. Reinserting it properly requires precise alignment, and there’s a real risk of damaging the internal mechanism or affecting valve calibration if forced.
What I’d suggest:
Check if it’s truly detached or just extended — sometimes the pushrod can sit flush or protrude slightly depending on the thermostat’s last state. Remove the batteries for 30 seconds to let it reset/retract, then reinstall them and see if it initializes normally[“content_id”:0"].
If it’s actually broken free — the thermostat likely needs replacement or professional service. The pushrod isn’t a separate spare part, and attempting to glue or press it back could jam the mechanism or cause inaccurate temperature control (plus potential valve damage).
For a definitive call on whether this is repairable under warranty, or to arrange a replacement:
Contact the Aqara Home App Customer Service Team (Profile > Help & Feedback > Customer Service) or scan the QR code:
This will be more efficient. If you do not have an Aqara Home account, Please click here to create a ticket.
Sorry this happened — mechanical failures on these small actuators are frustrating, but better to get it properly sorted than risk a leaky or stuck valve down the line.
It’s a press-fit connection, not threaded. Just align it properly and push it in until it snaps back into position. If it doesn’t stay in, check if any of the internal plastic retaining clips broke off when it detached.
Also, don’t forget to run a quick recalibration via the Aqara Home app once you snap it back in. This ensures the motor accurately senses the valve’s open and closed limit points.
@greggreg7 Welcome to the forum!!
