Hello everyone, I recently encountered an issue with my Echo device where it stopped responding. After deleting it from my account, I found myself unable to reconnect it. The device remained in setup mode with a persistent yellow circle, which was quite frustrating. I wanted to share my experience and the steps I took to resolve this issue, in case others are facing similar problems.
First, I tried the standard troubleshooting steps: resetting the device, checking Wi-Fi connectivity, and ensuring my account was correctly linked. However, none of these resolved the issue. I then reached out to Amazon support, who provided some additional insights. They suggested clearing the device’s memory and performing a factory reset, which I hadn’t considered initially.
After performing a factory reset, I attempted to connect the device again. This time, the process was successful. It seems that the device’s local memory might have been corrupted, causing the persistent setup mode. I also learned that ensuring a stable and strong Wi-Fi connection is crucial during the re-pairing process.
I would like to hear from others who have encountered similar issues. What steps did you take to resolve them? Have you found any additional tips or tricks that might help others in the same situation? Your experiences and advice are greatly appreciated!
