Echo Show 10 Issues and Siri Lock Controls
Hi everyone, I’ve been having some trouble with my Echo Show 10. For the past three days, it keeps saying ‘Sorry, something went wrong’ whenever I ask it a question. It’s connected to the internet, and my Echo Show 5 works fine. I’ve tried unplugging it multiple times, letting it sit, and restarting, but nothing seems to help. It looks like the Show 10 isn’t connecting to the Amazon servers. Has anyone else experienced this issue?
On a different note, I upgraded to iOS 15 recently, and I noticed that Siri now says she can’t lock or unlock my door via HomeKit integration, even though the action still happens. She controls lights and switches without any problems, so it seems to be a specific issue with locks. I tried re-adding the bridge, but it didn’t help. Anyone else seen this?
I’m also curious about the thermostat functionality in Home Assistant. I’m using Aqara battery temperature sensors with a Shelly plug to control my heater, and it works great! However, I would love to have a fail-safe mode where the thermostat turns off if the temperature sensor becomes unavailable. This would prevent the heater from running indefinitely if the sensor goes down.
Lastly, I’m trying to set up Pandora on my Home Assistant. I have pianobar installed and can run it via the command line, but when I try to use it through HA, I get a login error. The logs say the pianobar client isn’t configured to log in. I followed the instructions, but it still doesn’t work. Any ideas?
Thanks for any help or insights you can provide!
