Hey everyone, I wanted to share my experience with managing notifications across my Echo devices. I have an Echo Show in the living room and an Echo Dot in the bedroom. Initially, I was frustrated because all notifications were going to the Dot, which is annoying with its green/yellow light. I wanted notifications like delivery alerts to only go to the Show, which has a screen. After some digging, I found that it’s possible to control notifications by adjusting settings in the Alexa app. Here’s how I did it:
- Identify the Devices: Go to the Alexa app and navigate to the devices section. Locate both your Echo Show and Echo Dot.
- Adjust Notifications: Under each device, you can customize which notifications go where. I turned off shopping and delivery notifications on the Dot and made sure they were enabled on the Show.
- Test the Setup: I placed an order to test if the notification would only appear on the Show. It worked perfectly!
This setup has been a lifesaver. The Dot is now only used for essential notifications like the Ring doorbell, and the Show handles everything else. It’s much less disruptive now!
If anyone else is struggling with similar issues, I hope this helps. Happy smart home tweaking! ![]()
