ECO Heating Ultimate 1.1 and Better Thermostat Integration Issues
Hi all,
I’ve been using ECO Heating Ultimate 1.1 with Better Thermostat 1.3.0 for a while now, and it’s been working perfectly for the most part. I have a Eurotronic Spirit Z-Wave thermostat and an Aqara Zigbee window sensor set up. The system checks every 5 minutes, and when I open a window, the thermostat drops to 8°C, which is exactly what I want. When I close the window after 6 minutes, it goes back to the programmed setting. So far, so good!
However, I’ve noticed an issue when the window is left open for longer periods, say 30 minutes or more. When I close the window, the thermostat stays at 8°C, and the Better Thermostat dashboard card remains gray. I have to manually press the heat symbol to get it working again. Even waiting for 15 minutes doesn’t help. I assumed ECO Heating Ultimate would handle this since it checks every 5 minutes, but it seems like it’s not the case.
Has anyone else experienced this? Any ideas on how to fix it? I’d really appreciate any advice or workarounds you might have.
Thanks in advance!
Best regards,
