I’ve recently purchased an Ecobee thermostat and am in the process of setting it up. Upon removing my old thermostat, I noticed that I only have three wires, which is a bit concerning since the Ecobee requires a C-wire for power. However, I read through the Ecobee 3-wire guide and it seems like I might have a spare wire I can use. Let me share my findings and questions with the community to ensure I’m proceeding safely and correctly.
First, I noticed that the green wire is already connected to the C terminal on the furnace interface. I’m wondering if this is the correct setup. From what I understand, the green wire is typically used for the fan, but in some systems, it can also serve as the common wire (C-wire). I need to confirm if this is the case in my setup.
Next, I’m considering repurposing the yellow wire to serve as an additional C-wire. My question is, can I add this yellow wire to the existing green wire that’s connected to the C terminal on the control board? I’m concerned about potential issues with connecting two wires to the same terminal. Is this a safe practice, or could it lead to complications?
Lastly, I noticed a blue wire connected to the R terminal. This wire seems to be coming from the furnace but isn’t connected on the thermostat side. I’m wondering if I can repurpose this blue wire as the C-wire since it appears to be unused. If this is possible, it would solve my problem of needing an additional wire for the Ecobee setup.
I’m also concerned about the compatibility of my system with the Ecobee thermostat. If I can’t find a suitable wire to use as the C-wire, I might need to explore alternative solutions, such as using a battery or a power extender kit. However, I prefer to use the existing wiring if possible to maintain a clean setup.
If anyone has experience with similar setups or can provide guidance on repurposing wires, I would greatly appreciate it. Safety is my top priority, so I want to ensure that any changes I make are done correctly and won’t cause any issues with my furnace or thermostat.
Thank you in advance for your help and advice!
