I recently faced an issue with my humidity sensors where I was receiving alerts every 17 to 22 minutes, even when the humidity levels were within the desired range. After some investigation, I discovered that the sensor’s configuration page wasn’t accurately reflecting the real-time data, leading to unnecessary alerts. Here’s how I resolved the issue and optimized my setup:
Calibration Check: Ensure your sensor is properly calibrated. I found that a slight adjustment in the sensor’s placement reduced false readings significantly.
Adjust Thresholds: I revised the humidity thresholds to a narrower range, which helped in reducing frequent alerts. It’s important to balance sensitivity with practicality to avoid being overwhelmed by notifications.
Log Review: Regularly reviewing the logs helped me identify discrepancies between the sensor’s reported data and the configuration settings. This step was crucial in pinpointing the issue.
Firmware Update: Updating the sensor’s firmware to the latest version resolved some underlying issues that were contributing to the problem.
By implementing these changes, I achieved a more stable and reliable humidity monitoring system. If anyone else is experiencing similar issues, I recommend starting with calibration and log analysis before making any significant changes to your setup. Happy tinkering! ![]()
