Hey everyone, I wanted to share a really useful automation setup I’ve been working on to monitor and maintain the battery levels of my smart home devices. This has been a game-changer for me, especially with the growing number of sensors and devices I’ve added over time.
The Challenge
One common issue I’ve faced is keeping track of battery levels across multiple devices. With so many sensors spread out, manually checking each one is time-consuming and error-prone. I wanted a more efficient way to monitor these levels and get notifications when batteries are running low.
My Solution
I’ve created a custom template to count and monitor battery levels, which I’ve been refining over time. Here’s the basic setup:
python
{{ states.sensor | selectattr(‘attributes.device_class’, ‘eq’, ‘battery’) | selectattr(‘state’, ‘>=’, ‘90’) | list | length }}
This template counts how many sensors have a battery level above 90%. But I wanted to take it further. I modified it to specifically target sensors with “pir” in their entity_id, which helps me focus on motion detectors. For example:
python
{{ states.sensor | selectattr(‘attributes.device_class’, ‘eq’, ‘battery’) | selectattr(‘entity_id’, ‘contains’, ‘pir’) | selectattr(‘state’, ‘>=’, ‘90’) | list | length }}
I also added an average battery level calculation, which gives me a quick overview of how my sensors are performing overall. This has been incredibly helpful for proactive maintenance.
Automation in Action
The real magic happens with automation. I’ve set up notifications that alert me when any device’s battery drops below a certain threshold. This means I can replace batteries before they cause issues, avoiding any downtime or inconvenience.
Why This Matters
Maintaining battery levels isn’t just about convenience. It ensures that my security system stays reliable, especially with motion sensors. Plus, knowing which devices need attention helps me plan maintenance efficiently, saving me time in the long run.
Tips for Others
If you’re looking to implement something similar, here are a few tips:
- Start Small: Begin with a few sensors and gradually expand your setup as you become more comfortable.
- Regular Checks: Even with automation, it’s good to manually check a few devices periodically to ensure everything is working as expected.
- Customize Alerts: Tailor your notifications to your specific needs. You might want alerts for different battery levels or different types of devices.
This setup has made managing my smart home much easier. I’d love to hear how others are handling battery monitoring and if you’ve found any other useful tricks or tools!
Cheers, [Your Name]
