I recently upgraded my lighting setup with Wyze V3 bulbs, aiming to enhance my home security by monitoring motion activity, especially for capturing meteors. However, I encountered a frustrating issue where the playback feature only allowed me to watch one minute of recorded footage at a time. This limitation forced me to manually adjust the playback slider every minute, which was quite tedious, especially for extended observations.After some research and experimentation, I discovered a workaround that leverages the Wyze app’s event notifications and the built-in scheduling features. Here’s how I optimized my setup:1. Event Notifications Configuration: I enabled motion detection on all my bulbs and set the sensitivity to a moderate level to avoid false triggers. This ensures that only significant movements are recorded.2. Scheduled Recordings: Instead of relying solely on motion detection, I configured the bulbs to record continuously during specific times when I’m most likely to observe meteor activity. This approach ensures that I don’t miss any events, even if motion detection fails to trigger.3. Playback Automation: To address the playback limitation, I created a simple script that automatically adjusts the playback slider every minute. This script runs in the background, allowing me to watch extended periods of footage without manual intervention.4. Integration with Home Automation: I integrated the Wyze bulbs with my existing smart home system, enabling them to trigger other devices, such as cameras or alarms, during detected motion. This integration significantly enhances my home security setup.Through these adjustments, I’ve managed to overcome the initial limitations and create a more efficient and enjoyable motion detection system. If you’re facing similar challenges with your Wyze bulbs, I hope this guide helps you optimize your setup as well!
