Hi all, I’ve been working on setting up notifications for my smart home sensors, and I wanted to share my experience in case it helps someone else. I have a variety of sensors—door, window, flood, and motion detectors—and I wanted to make sure each notification was clear and specific.
Initially, I used the default notifications provided by the sensor apps, but I quickly realized a problem: when multiple sensors trigger alerts, it’s hard to tell which one is which. For example, if both my front door and back door sensors go off, I need to know exactly which door is open to respond appropriately.
I tried setting up static text in the notification panel, but that didn’t solve the issue. It just repeated the same message for every sensor. I needed a way to include dynamic information, like the device name or room, in the notification text. After some research, I found that using a third-party automation app like IFTTT or SmartThings allowed me to customize notifications with variables.
Here’s how I did it: I created rules in SmartThings that trigger when a sensor is activated. The rule sends a notification that includes the device name and room using variables. For example, when my living room motion sensor detects movement, it sends a notification that says, ‘Motion detected in Living Room.’ This way, I know exactly where the activity is happening.
I also shared this solution in the Fibaro community, and others found it helpful. If you’re struggling with similar issues, I highly recommend exploring automation apps for more flexible notification options. It’s made my smart home setup much more user-friendly! ![]()
