Efficient Pool Automation with Konnected: A Step-by-Step Guide
I recently embarked on a project to automate my Pentair SuperFlow VS pool pump using Home Assistant, and I’m thrilled to share my journey and insights. The goal was to create a cost-effective, DIY solution that allows me to control the pump via voice commands, schedules, and more. Here’s how I achieved it:
The Challenge
Initially, I was daunted by the high costs of commercial automation solutions. After some research, I discovered that the control system was essentially a low-voltage relay setup. This realization opened the door to a more affordable DIY approach.
The Solution
I opted for Konnected, a versatile and user-friendly platform. Here’s why:
  • Ease of Use: No coding required beyond Home Assistant configurations.
  • Affordability: The total cost, including the proprietary Pentair cable, came in at around $115, a fraction of the commercial options.
  • Customization: Konnected allowed me to integrate seamlessly with Home Assistant, enabling voice controls and scheduling.
Setup Overview
  1. Hardware Setup: I used a 6-zone Konnected relay kit, which provided the necessary control over the pump’s speed and schedule.
  2. Configuration: Detailed configurations in configuration.yaml and automations.yaml ensured smooth operation. I set up input datetimes for scheduling and templates for dynamic speed adjustments.
  3. Automation: I created automations to handle speed changes, ensuring only one speed is active at a time. This prevents the pump from shutting off unintentionally.
  4. User Interface: A Lovelace card was designed to display the pool control interface, making it easy for anyone in the household to adjust settings.
Results and Satisfaction
This project has been a game-changer. Not only did it save me thousands of dollars, but it also provided a reliable and customizable solution. The ability to control the pool pump via voice commands or schedules has added a new level of convenience to my routine.
Tips for Success
  • Plan Thoroughly: Spend time understanding your equipment’s manual to identify control points.
  • Start Small: Begin with basic controls and gradually add more features as you become comfortable.
  • Leverage Community Resources: The Home Assistant community is invaluable. Documentation and forums were instrumental in overcoming challenges.
This project has been both rewarding and educational. It’s a testament to the power of DIY solutions and the flexibility of platforms like Home Assistant. If you’re looking to automate your pool or any similar system, I highly recommend exploring Konnected and Home Assistant. The journey is as fulfilling as the result!
Happy automating! :ocean::sparkles:
