Efficient Smart Home Automation with Flirc Dongle
I recently decided to enhance my smart home setup by integrating a Flirc dongle to control Home Assistant using a keyboard remote. Initially, I was a bit overwhelmed, but the process turned out to be quite rewarding!
Setup Journey
After purchasing the Flirc dongle, I spent some time researching the best way to configure it with Home Assistant. The official documentation and community forums were incredibly helpful. I started by testing the hardware using the hassio host hardware command, which confirmed that the device was recognized.
Configuration Challenges
The trickiest part was figuring out the correct device descriptor for the Flirc input. I experimented with different paths like /dev/input/event0 and /dev/input/by-id/flirc.tv_flirc before settling on the right one. Once that was sorted, I set up the keyboard_remote integration in my configuration.yaml file.
Automation Success
I created a simple automation to test the setup. The goal was to trigger a script when a specific key was pressed. Here’s a snippet of my automation:
yaml
initial_state: ‘on’
alias: Key Up
trigger:
platform: event
event_type: keyboard_remote_command_received
event_data:
key_code: 38
action:
service: script.turn_on
entity_id:
- script.press_up
Everything worked seamlessly! Pressing the key now reliably triggers the desired action.
Lessons Learned
This experience taught me the importance of thorough testing and the value of community resources. If you’re considering a similar setup, I recommend starting with basic automations and gradually expanding as confidence grows.
Integrating the Flirc dongle has added a new layer of convenience to my smart home. It’s amazing how such a small device can enhance control over the system. I’m now looking forward to exploring more advanced automations!
Thanks to the supportive community for all the guidance! :raised_hands:
