Efficient Smart Home Migration: My Experience Moving House
Moving house with a well-established smart home system can be both exciting and overwhelming. After spending several years building my smart home ecosystem with Hubitat, I found myself in the position of relocating and faced the challenge of transporting over 390 devices and 32 apps. I wanted to share my experience and insights on how to approach this process effectively.When I first considered moving, I wondered whether it would be better to start fresh or attempt to reintegrate all my existing devices into the new environment. After some research and discussions within the community, I decided to keep my existing setup but make adjustments as needed. This approach saved me time and allowed me to leverage the automations I had already built.One of the key lessons I learned was the importance of organization. I created a detailed inventory of all my devices, noting their current configurations and integration points. This helped me keep track of what needed to be moved and what could potentially be left behind. I also took the time to label everything clearly, which made the packing and unpacking process much smoother.In the new home, I started by setting up the core components first—my Hubitat hub, the primary network infrastructure, and essential security devices. Once these were in place, I gradually reintegrated the other devices, testing each one as I went. This methodical approach helped me identify and address any issues early on.I also found that naming conventions and room assignments were crucial. By consistently naming devices and assigning them to the correct rooms, I maintained clarity in my system and made it easier to manage automations. I recommend spending extra time on this step, as it pays off in the long run.One unexpected benefit of the move was the opportunity to streamline my setup. I discovered that some devices were no longer necessary or had become redundant, allowing me to simplify my system. This was a silver lining that I hadn’t anticipated but appreciated.Overall, my experience taught me that while moving a smart home can be challenging, it’s manageable with careful planning and organization. It’s also a great opportunity to reassess and improve your setup. I hope my insights can help others who are facing a similar situation. Happy moving and happy automating!
