Efficiently Powering Two Wyze Outdoor Cameras with One Solar Panel
I wanted to share a successful solution I found for powering two Wyze Outdoor cameras using a single solar panel. This setup has been working perfectly for the past few weeks, and I thought it would be helpful to share the details in case others are looking for a similar solution.
What You’ll Need
  • Wyze Outdoor Cameras (V1 or V2)
  • Solar Panel (I recommend the Wyze or Wasserstein models available on Amazon)
  • ELECTOP Micro USB Female to 2 Micro USB Male Splitter Cable (available on Amazon)
  • Black Thick Electrical Tape
  • PEF Mount for All-new Wyze Cam Outdoor (available on Amazon)
  • Medium Drill Bit and Drill
Setup Instructions
  1. Solar Panel Placement
    • Ensure the solar panel is placed in direct sunlight for at least a week before use. This allows the built-in battery to fully charge, ensuring it can provide the necessary voltage to power both cameras simultaneously.
  2. Drilling the Mount
    • Use the PEF mount to secure the solar panel. Drill a small hole where the Micro USB splitter will connect to the camera port. This step is crucial for a clean and weatherproof installation.
  3. Connecting the Splitter
    • Attach the Micro USB splitter to the solar panel. This allows both cameras to be powered from a single panel. Use the electrical tape to seal the connection between the splitter and the solar panel, ensuring it is completely weatherproof.
  4. Sealing the Connections
    • After drilling the hole for the splitter, apply silicone sealant to cover the gap. This prevents any moisture from entering and damaging the equipment.
  5. Final Assembly
    • Connect the splitter to both cameras. The setup should now be fully operational, with both cameras receiving power from the single solar panel.
Tips and Considerations
  • Battery Activation: The solar panel has a small battery that needs to be fully charged before it can power both cameras. This ensures the panel provides the necessary voltage to charge both devices simultaneously.
  • Weatherproofing: The use of silicone sealant and electrical tape is essential to protect the connections from the elements.
  • Placement: Ensure the solar panel is placed in an area that receives ample sunlight throughout the day.
Conclusion
This setup has been a game-changer for me, allowing me to power two Wyze Outdoor cameras with a single solar panel. It’s a cost-effective and eco-friendly solution that ensures my cameras are always powered, regardless of the weather conditions. I hope this guide helps others looking to implement a similar setup. If you have any questions or need further clarification, feel free to ask!
Happy tinkering! :sun_with_face:
