Energy Bill Calculation with Home Assistant: A Comprehensive Guide
I recently embarked on a project to calculate my energy bill using data from my Solar Inverter, and I wanted to share my journey and findings with the community. This project was born out of a desire to have real-time insights into my energy usage and costs, which most people overlook. I hope this guide helps others in a similar situation!
What You’ll Need Before Getting Started
Before diving in, ensure you have the following:
  • A device capable of measuring energy flow, such as a Current Transformer (CT) Clamp.
  • Access to your power plan details, including rates and fees.
  • A solar system with an inverter (like the Enphase Envoy) connected to your network.
The Setup Process
  1. Measuring Energy Flow: I used a CT Clamp on the wire coming out of my energy meter, which connects to my solar inverter. This setup allows Home Assistant to extract energy consumption and production data.
  2. Configuring Sensors: I set up sensors to track grid import/export power and energy. This involved some basic math to convert power (Watts) into energy (kWh).
  3. Tariff Management: My energy plan has complex time-of-use (TOU) rates, so I used the Utility Meter integration to track energy consumption across different tariffs.
  4. Automation: I created automations to switch tariffs based on time and season, ensuring accurate cost calculations throughout the year.
Key Takeaways
  • Tariff Configuration: I assigned different rates to peak, shoulder, and off-peak periods, reflecting my energy provider’s rates.
  • Export Credits: I set up separate tariffs for solar export, which change based on the amount of energy exported during the day.
  • Daily Service Charge: I included a daily service charge in my calculations to ensure accuracy.
Tips for Success
  • Use Current Transformers: They provide accurate measurements of energy flow, which is crucial for reliable calculations.
  • Leverage Home Assistant’s Integration Capabilities: The Integration and Utility Meter integrations are powerful tools for this project.
  • Customize Your Tariffs: Tailor your tariff setup to match your energy plan’s specifics, including any discounts or seasonal changes.
How It’s Changed My Habits
Seeing real-time energy costs has made me more mindful of my consumption patterns. I now actively adjust my usage during peak periods to minimize costs.
If you’re looking to gain better control over your energy bills, I highly recommend exploring this project. It’s a bit involved, but the insights and savings it provides are well worth the effort. Happy tinkering!
