I’ve been puzzling over this strange energy consumption issue with my Roller Shutter 3 on the HC3 hub. On August 19th, 2026, I noticed that the Energy Panel showed a consumption of 2.73 kWh for one of the shutters. However, when I checked the product settings, the graph displayed a blue line at 0, while the energy consumption section clearly showed 2.73 kWh. This discrepancy is quite puzzling, especially since I wasn’t even at home to witness any unusual activity. Is this a bug, or is there something I’m missing?
I’ve reached out to the community to see if others have encountered similar issues. It’s fascinating to see how everyone troubleshoots and shares their experiences. For instance, someone mentioned that they had to manually reset their energy settings after a firmware update, which got me thinking—could a similar approach work here?
In the meantime, I’ve been monitoring the energy consumption more closely. I’ve set up a simple automation rule to log the energy usage every hour. It’s a bit of a hack, but it helps me keep track of any anomalies. Here’s a quick tip for anyone else dealing with energy monitoring: always check both the panel display and the product settings for consistency. Sometimes, what you see on the surface isn’t the full story!
If anyone has insights or suggestions, I’d be thrilled to hear them. Let’s crack this mystery together! ![]()
