Hi everyone, I wanted to share an exciting project I’ve been working on with my mini campsites. The goal here was to not only replace the service poles but also integrate some energy monitoring to gain better insights into consumption patterns. It’s been a mix of challenges and triumphs, and I’d love to hear your thoughts!
Initially, I was unsure about the best way to approach the energy monitoring aspect. After some research, I decided to go with a simple yet effective solution: adding power strips with built-in energy meters. These strips are perfect because they fit neatly into the existing service boxes and provide real-time data without any major hassle.
One of the key questions I had early on was whether to use Wi-Fi 4.2 or 5, and whether to stick with Zigbee or try Z-Wave. After some testing, I found that Zigbee offered a more seamless integration with my existing setup, especially since I already have several Zigbee devices in place. The transition was smooth, and I didn’t encounter any major compatibility issues.
Another consideration was ensuring that the power strips could handle power outages gracefully. I was relieved to find that they automatically resume power without needing any manual intervention, which was a critical requirement for this project.
So far, the results have been fascinating. I’ve been able to track energy usage patterns across the different campsites, which has already led to some interesting insights. For example, certain times of the day see a significant spike in consumption, which I can now address more effectively.
I’m also experimenting with integrating this data into my home automation system. The idea is to create a dashboard that provides a real-time overview of energy usage across all campsites. It’s still a work in progress, but the potential is enormous!
If anyone has tips or suggestions on how to further optimize this setup, I’d love to hear them. Whether it’s about improving data accuracy, exploring different communication protocols, or even suggesting alternative devices, your input would be invaluable.
Thanks for reading, and I look forward to hearing your thoughts!
