I recently decided to upgrade my bathroom lighting system to make it smarter and more convenient. After some research, I chose the Govee smart LED light strips combined with Shelly switches. The installation process was straightforward, and the results have been fantastic!
Initially, I faced a minor issue with the light strips resetting to a default setting whenever they were turned off and back on. However, I discovered that using the Govee app, I could set a ‘last state’ memory feature, ensuring the lights return to the desired setting. This was a simple fix that made a big difference.
I also integrated the Shelly switches into my existing smart home setup, allowing me to control the lights via voice commands or the app. It’s wonderful to walk into the bathroom in the morning and have the lights automatically adjust to a warm, inviting setting.
One tip I’d like to share is experimenting with different color modes. I found that a soft white setting is perfect for daily use, while a slightly cooler tone is better for tasks like applying makeup. The Govee app makes it easy to switch between these settings with just a few taps.
Overall, this upgrade has made my mornings more enjoyable and has added a touch of modern convenience to my bathroom routine. I highly recommend exploring Govee and Shelly products if you’re looking to enhance your home’s lighting system.
