I’ve recently been diving into the world of Bayesian Sensors in Home Assistant, and I must say, it’s been a game-changer for my smart home setup!
After several months of experimentation, I’ve developed what I believe to be a solid approach to utilizing this powerful tool effectively.
Bayesian Sensors allow you to make probabilistic decisions based on multiple observations, which is perfect for complex scenarios like determining whether the house is empty or not. For instance, if both my partner and I are more than 50 miles away from home, the likelihood of us being away overnight increases significantly. Combining this with other observations, like no motion detected in the house, helps create a robust system that triggers automations accordingly.
One of the key challenges I faced was fine-tuning the probabilities and thresholds. After some trial and error, I found that setting a prior probability of 0.4 and a threshold of 0.98 worked well for my setup. This configuration ensures that the sensor only triggers when there’s a high confidence that the conditions are met.
To make the process more efficient, I created a simple Excel model to simulate different scenarios. This allowed me to tweak the probabilities without constantly restarting Home Assistant. The model helped me understand how each observation impacts the overall probability, making the entire process much smoother.
Another feature I love is the ability to add overrides using input booleans. This gives me a handy way to force the sensor into a specific state if needed, which is incredibly useful for testing or special cases.
Overall, Bayesian Sensors have significantly improved my home automation experience. They’ve allowed me to create more intelligent and responsive systems that adapt to our lifestyle. If you’re looking to take your smart home setup to the next level, I highly recommend giving Bayesian Sensors a try! ![]()
