Enhancing Home Automation with Nanoleaf Light Transitions
I recently stumbled upon a fantastic solution to enhance my Nanoleaf Essentials setup, and I just had to share it with the community! For those who enjoy smooth transitions in lighting, you’ll know that the built-in method doesn’t always deliver the desired results. However, I came across a clever script that allows you to add transitions to your automations and scripts, making your lighting experience much more seamless.
The script introduces a boolean input, transition_running, which acts as a toggle. This is incredibly handy for scenarios like my home theater setup. When the TV turns on, the lights dim, and when it stops, they slowly brighten back. But here’s the kicker: if I pause and then unpause a show, the lights start dimming immediately without waiting for the previous transition to complete. This is a game-changer for anyone looking to refine their automation flows!
Another use case I’ve implemented is integrating this script with my circadian lighting automation. Without pausing, both systems would try to adjust the lights simultaneously, causing a command overload. The transition_running boolean makes pausing and resuming this automation a breeze, ensuring everything runs smoothly.
If you’re interested in trying this out, the script is well-documented and easy to adapt to your setup. It’s all about making your smart home experience more intuitive and enjoyable. Let me know if you have any questions or feedback—I’d love to hear how you enhance your setup with this!
Happy automating! :rocket:
