As a long-time user of Tado’s smart home solutions, I’ve been thoroughly impressed with the system’s reliability and ease of use. However, one recurring issue that has occasionally caused frustration is the reliance on a separate bridge device for controlling heating and ventilation systems. While the current setup works well, the potential for bridge-related failures is a concern, especially for those with extensive installations.
I propose an exciting enhancement: integrating WiFi support directly into the Tado extension kits. Since these kits are already mains-powered, adding WiFi would eliminate the need for a separate bridge, streamlining the system and reducing points of failure. This change would not only simplify installations but also improve overall system reliability.
To ensure optimal performance, especially in larger properties where extension kits might be located at a distance, it would be beneficial to include mesh networking capabilities. This would allow for robust and reliable communication between all devices, even in challenging environments.
I’m curious to hear others’ thoughts on this idea. Have any of you encountered issues with bridge devices, or do you see additional benefits to integrating WiFi directly into extension kits? Let’s discuss how this could further enhance our smart home experiences!
