As a homeowner passionate about creating a comfortable living environment, I’ve recently delved into automating my ventilation system using Home Assistant. My goal was to ensure optimal air quality, especially in areas like the bedroom where CO2 levels can rise, affecting sleep quality. Here’s how I approached it and what I learned along the way.### The SetupI started by installing a CO2 sensor in my bedroom. The sensor measures CO2 levels in parts per million (ppm), providing real-time data. I paired this with a ventilation system that has three adjustable speeds, controlled via Home Assistant buttons. The system’s automation is designed to adjust the ventilation speed based on CO2 levels.### The Automation LogicThe core of the system is an automation rule that triggers based on the CO2 sensor readings:- Below 700 ppm: The ventilation runs at low speed to maintain fresh air without over-ventilating.- 700-1000 ppm: The system switches to medium speed to increase airflow and reduce CO2 levels.- Above 1000 ppm: High-speed ventilation kicks in to rapidly circulate fresh air.### A Challenge and Its SolutionOne challenge I encountered was ensuring the system respects manual overrides. For instance, if CO2 levels are below 700 ppm but I manually set the ventilation to high speed, the system shouldn’t revert to low speed. To address this, I integrated a condition in the automation rule that checks if the ventilation speed was manually adjusted. If so, the automation pauses, allowing manual control to take precedence.### Testing and OptimizationTesting the system was crucial. I monitored the CO2 levels and ventilation responses over several days, adjusting thresholds and automation rules as needed. It was fascinating to see how the system adapted to different scenarios, such as after workouts or during guests’ visits when CO2 levels spiked.### Results and SatisfactionThe outcome has been fantastic. My bedroom now maintains consistently fresh air, which I can monitor through Lovelace dashboards. The system’s responsiveness has been a game-changer, especially during the night when CO2 levels tend to rise. It’s reassuring to know that my home is actively managing air quality without constant manual intervention.### Looking AheadThis project has inspired me to explore further automation possibilities. I’m considering expanding the system to other areas of the house and integrating it with other smart home features, like adjusting HVAC settings based on ventilation activity.### Final ThoughtsAutomating my ventilation system has been a rewarding experience. It combines technology with practicality, enhancing comfort and efficiency. I encourage others to explore similar projects, as the benefits in terms of indoor air quality and overall home comfort are well worth the effort.
