I recently set up my Home Safety Monitoring (HSM) system to keep an eye on potential leaks and battery levels around my home. It’s been a great addition to my smart home setup, giving me peace of mind knowing that I’ll be alerted if something goes wrong. I armed both the Water and Custom services through the HSM app, and everything seemed to be working smoothly at first glance. However, I noticed an issue with the dashboard icon—it remained red, indicating it was disarmed, even though the configuration showed it was armed. This was a bit confusing, but after some troubleshooting, I realized that I needed to ensure all services were correctly integrated and that there were no conflicting settings. Once I adjusted the configurations, the icon finally turned green, and I could breathe a sigh of relief. The app has been sending accurate alerts for both leaks and low batteries, which is exactly what I wanted. If you’re considering setting up a similar system, I recommend thoroughly checking all service integrations and configurations to avoid any issues. It’s also a good idea to test the alerts by triggering them manually to ensure they work as expected. Overall, this setup has been a reliable way to monitor my home’s safety, and I’m glad I took the time to get everything just right.
