I’ve been exploring innovative ways to protect my garden from deer while maintaining a beautiful landscape. After some research, I stumbled upon the idea of using a Wyze Motion Sensor to trigger a sprinkler system. The concept is simple yet effective: detect motion and deter intruders with a sudden burst of water.
Initially, I set up the Wyze Motion Sensor and connected it to an Amazon Plug. The idea was to have the sprinkler activate for a set duration whenever motion was detected. However, I encountered an unexpected issue—after a short while, the sprinkler would shut off prematurely. This was puzzling because I couldn’t find any clear instructions on how to adjust the timing or override the sensor’s detection.
I decided to dig deeper into the Wyze Motion Sensor’s capabilities. Through the app, I discovered that it uses Passive Infrared (PIR) sensors to detect heat signatures. This made me wonder if the water from the sprinkler might be affecting the sensor’s ability to detect motion accurately. Could the water droplets or moisture somehow interfere with the sensor’s operation?
After some experimentation, I realized that the sprinkler’s spray wasn’t directly causing the sensor to malfunction. Instead, the issue lay in the automation settings. The Wyze Motion Sensor was designed to shut off after a certain period, but I needed a way to extend this duration or disable it entirely when the sprinkler was active.
I reached out to the Wyze community and found a workaround. By adjusting the sensor’s settings and integrating it with Home Assistant, I was able to create a more reliable automation. Now, the sprinkler activates for a consistent 30-second burst whenever motion is detected, providing a strong deterrent without any premature shutdowns.
This project has been a fantastic learning experience. It not only helped me protect my garden but also improved my understanding of smart home integrations. If anyone else is looking to implement a similar system, I’d recommend starting with a basic setup and gradually refining it based on real-world testing. Happy gardening and happy automating! ![]()
