After exploring various ways to improve my home security setup, I stumbled upon a fantastic feature in Home Assistant that allows for rolling alerts using a marquee effect. This has been a game-changer for keeping track of multiple sensors and alerts in one glance. Here’s how I implemented it and how you can too!
My Setup
I have several sensors around my home, including temperature sensors, motion detectors, and system alerts. Previously, I found myself toggling between different cards to check each sensor individually. With the marquee effect, all these alerts are consolidated into one neat card.
The Process
Research and Inspiration
I came across a custom card solution in the Home Assistant community that uses a marquee tag to create a scrolling effect. This seemed perfect for my needs as it allows multiple pieces of information to be displayed in a single space. -
Custom Card Configuration
I utilized thecustom:button-cardto create a dynamic card that pulls data from various sensors. The key was to use HTML within the card’s configuration to achieve the marquee effect. Here’s a snippet of my configuration:
markdown
[[[return `
Color Customization
To make the alerts more visually distinct, I used built-in color variables likevar(--primary-color)for system alerts. This ensures consistency with the overall theme of my dashboard. -
Continuous Improvement
While the initial setup worked, I realized that hardcoding sensor names made it less flexible. My next step is to replace these with card variables so I can easily update them without rewriting the entire card.
Why This Matters
This setup has significantly improved my peace of mind. Now, I can quickly scan through all relevant alerts without navigating through multiple cards. It’s especially useful during mornings when I want a quick overview before starting my day.
Looking Ahead
I’m excited to explore more customizations and possibly integrate this with other parts of my automation setup. If you’re looking to streamline your security monitoring, I highly recommend giving this a try!
Feel free to reach out if you have questions or suggestions for improvement. Happy automating! ![]()
