Hey everyone! I’ve been trying to set up a smart meter sensor in my home, but I’ve encountered an issue where the LED signal from the sensor isn’t being detected by my Kamstrup smart meter. I thought it might be a hardware issue, but after some troubleshooting, I realized the LED might just be too weak. Let me walk you through what I’ve tried and what I’m planning to do next.
First, I connected the sensor to my PC’s LED to test if it works, and it did! This means the sensor itself isn’t the problem. The issue must be with the LED’s brightness or how it’s positioned relative to the smart meter. I noticed that the plastic housing of the sensor has a textured surface that might be scattering the light, making it harder for the meter to detect. Unfortunately, I can’t open the meter to adjust anything since it’s sealed by the energy provider.
I’ve considered a few creative solutions to boost the LED’s signal. One idea is to use a reflective material to focus the light more directly at the meter. I’m also thinking about installing an external amplifier or using a different LED configuration. If anyone has experience with similar issues or knows of a reliable method to enhance LED signals, I’d love to hear your suggestions!
In the meantime, I’ll try attaching a small mirror or reflective tape near the LED to see if that helps. I’ll also look into whether there are any firmware updates or settings adjustments for the sensor that might improve the signal strength. If all else fails, I might need to explore alternative sensors that are better suited for my setup.
This has been a bit of a puzzle, but I’m determined to get it working. Thanks in advance for any advice or tips you can share!
