Enhancing RESTful Sensor Functionality with Dynamic Headers
I recently stumbled upon a feature request that resonated with many users in the community, and I wanted to share my thoughts and experiences with you all. The topic revolves around the ability to use dynamic headers in RESTful sensors, particularly for APIs that require frequent token updates. This is a common challenge for those integrating modern APIs into their home automation setups.
For instance, my setup uses a RESTful sensor to monitor a third-party service. The service requires an OAuth Bearer token that changes every 24 hours. Manually updating this token in the sensor configuration is not only tedious but also error-prone. Ideally, the sensor should be able to dynamically pull the token from another sensor or entity within Home Assistant. This would streamline the integration process and make it more robust.
The proposed solution involves adding template support to the headers attribute in RESTful sensors. Here’s a conceptual example of how this could work:
yaml
sensor:
  • platform: rest
    resource: “http://domain/my/api”
    headers:
    Authorization: “Bearer {{ state_attr(‘sensor.access_token’, ‘token’) }}”
    value_template: ‘{{ value }}’
    scan_interval: 30
This approach would allow one sensor to fetch the token and store it, and another sensor to use this token dynamically in its headers. It would significantly enhance the flexibility and scalability of RESTful sensors in Home Assistant.
I’m curious to hear others’ experiences with similar challenges and whether they’ve found workarounds or innovative solutions. Have you successfully integrated dynamic headers in your setup? What hurdles did you encounter, and how did you overcome them? Your insights could be invaluable to the community!
Let’s continue this discussion and explore how we can make this feature a reality. Your feedback and suggestions are crucial in shaping the future of Home Assistant integrations.
