I recently encountered an issue with my Zooz ZSE18 motion sensor, where I noticed it was overly sensitive during daylight hours. After some research, I discovered that adjusting the sensitivity settings could solve this problem. However, I faced challenges in implementing these changes through the provided DHT code.
Through experimentation, I found that utilizing Z-Wave configuration commands was the key to modifying the sensitivity settings. I successfully sent these commands to the device, which allowed me to reduce its sensitivity during the day. This adjustment has significantly improved my smart home experience, ensuring that the sensor only triggers when necessary.
If anyone else is struggling with similar issues, I recommend exploring Z-Wave configuration commands as a potential solution. It’s a bit technical, but with patience, it can lead to optimal performance of your devices. Happy tinkering! ![]()
