As a homeowner passionate about optimizing my smart home setup, I’ve been exploring ways to enhance the efficiency of my Tado smart thermostats. I recently noticed an interesting behavior with the radiator valves when the desired temperature is reached. The valve shuts off immediately, which, while precise, might be causing some inefficiency in my heating system.
In my setup, the central heating boiler continues to run briefly after the radiator valve closes, leaving unused heated water in the system. This unused heat isn’t just wasted energy; it’s also a missed opportunity to maximize the efficiency of my heating system. I recall that some heating systems include a feature where the pump continues to run for a short period after the temperature is reached, allowing the system to fully utilize the heated water before shutting down. This seems like a logical improvement that could be integrated into the Tado system.
I propose a new feature: an ‘after-run-time’ option for radiator valves. When the set temperature is achieved, the valve would remain open for a configurable period, say 5-10 minutes, allowing the pump to circulate the remaining heat. This delay would not only reduce energy waste but also potentially extend the lifespan of the boiler by preventing rapid on/off cycling.
I’m curious to hear if others have encountered similar issues or if there’s already a workaround for this. It would be fantastic if Tado could consider this enhancement in future updates. After all, every small tweak can contribute to a more efficient and sustainable home environment!
Let’s keep the conversation going and share our experiences and ideas for improving our smart home setups. Together, we can make our homes not just smarter, but also greener and more efficient.
