Hey everyone, I wanted to share a really cool tip that I stumbled upon recently while trying to streamline my Home Assistant setup. I’ve been using Home Assistant for a while now, but I must admit, I wasn’t fully utilizing the power of customizations until recently. Let me walk you through my journey and how I managed to simplify my workflow significantly.
The Problem
I have a setup where I use input_select entities to control various devices around my home. For instance, I have input_selects for different rooms that let me choose whether I want to turn on the lights, fans, or heaters in those areas. Initially, my flows were quite clunky. I had separate state change triggers for each input_select and corresponding get state nodes for each device. This worked, but it was repetitive and hard to maintain, especially as I added more devices to my setup.
The Solution
After some research, I discovered that I could use custom attributes in my customize.yaml file to map each input_select to its corresponding device. This was a game-changer! Here’s how I did it:
Adding Custom Attributes:
I added a custom attribute calledfanto each of my input_select entities. This attribute holds the entity ID of the fan that corresponds to each input_select. For example:
yaml
input_select.fan_office:
fan: fan.office_fanThis way, each input_select knows exactly which fan it controls.
Simplifying the Flow:
Instead of having multiple state change triggers, I now use a single trigger with a substring criteria ofinput_select.fan. This means any input_select that follows this naming convention will automatically be picked up by the flow. The magic happens when I retrieve the corresponding fan entity using the custom attribute. I use a simple mustache template to dynamically fetch the fan entity ID:{{data.new_state.attributes.fan}}
This allows the flow to dynamically adjust based on which input_select was changed.
The Benefits
This approach has been transformative for me. Not only has it simplified my existing flows, but it’s also made adding new devices much easier. For example, if I want to add another input_select and fan combo, I just need to add the new entries to my customize.yaml file and the flow will handle the rest without any additional setup.
I’m now looking to apply this same principle to other parts of my setup, like door sensors and lights. The possibilities are endless, and it’s all thanks to the flexibility of custom attributes in Home Assistant.
A Word of Encouragement
If you’re someone who’s been hesitant to dive into customizations, I encourage you to give it a try. It might seem a bit daunting at first, but the payoff in terms of efficiency and maintainability is well worth it. Plus, the community here is fantastic. If you run into any issues or have questions, feel free to reach out. I’m sure someone will be happy to help!
