Wow, this product is a game-changer! I just installed the Envisual TV Backlight T2 on my 55-inch TV, and the results are absolutely stunning. Let me share my experience in case it helps others who might be considering this upgrade.
The installation process was smooth, but I encountered a small hiccup. My TV wasn’t completely flat on the back, which initially worried me. To ensure the LED strips adhered properly, I cleaned the surface thoroughly with rubbing alcohol and applied pressure section by section. This method worked perfectly, and now the strips are holding like a charm!
One minor detail I noticed is a slight overhang in the corners, but it’s completely invisible from the front. I plan to use some tape to secure it neatly behind the TV. The most challenging part was the camera calibration on my iPhone 14 Pro Max—it was a bit tricky due to poor lighting, but I managed to figure it out after some trial and error.
Once everything was set up, the results were nothing short of amazing. The white balance and color saturation are spot on, and watching hockey with this backlight is an entirely new experience. I’m already excited to try it out with movies!
I also managed to connect my Hexa Pro Light Panels, and the combination is simply breathtaking. If you’re looking to elevate your home theater setup, I highly recommend giving this product a try. The installation is straightforward, and the payoff is well worth the effort!
#GoveeDelivers
