ESP Home Multi-Speed Fan Conversion Success Story
I recently embarked on a project to convert a standard three-speed fan into a smart, ESP Home-controlled device. After some research, I came across a helpful YouTube video that guided me through the process using ESPHome and Sonoff modules. Here’s how I made it happen!
First, I set up my ESP32 module with three relays, ensuring they were properly interlocked to prevent simultaneous operation. The key challenge was integrating a single momentary button to toggle between the fan’s three speeds. I programmed the ESP to detect the button press and cycle through the relays accordingly. The interlock feature was crucial to prevent any electrical mishaps.
I also utilized the ESPHome binary_sensor platform to handle the button input and automate the relay switching. The configuration involved setting up GPIO pins for each relay and defining their interlock groups. This setup ensures smooth transitions between low, medium, and high speeds with a simple button press.
Testing was a breeze once everything was wired up. The fan now responds flawlessly to button presses, cycling through speeds without any hiccups. I’m thrilled with how this project turned out and highly recommend ESPHome for anyone looking to add smart functionality to their home appliances. The community support and resources available made this project both enjoyable and educational!
If you’re considering a similar project, I’d suggest starting with a thorough understanding of your hardware and taking your time with the configuration. Happy tinkering! :rocket:
