ESP01 Integration with OpenHAB3 and Bosch Dishwasher Automation
Hey everyone, I’m really excited to share my recent experiences with integrating an ESP01 module into my OpenHAB3 setup and figuring out how to automate my Bosch dishwasher. It’s been a bit of a journey, but I’ve learned so much along the way!
Starting with the ESP01 integration, I programmed it using Arduino IDE to create a simple lighthouse sequence with an LED. The goal was to control this sequence using an OpenHAB3 HTTP binding switch. I followed some online guides, including this helpful post, but I kept running into issues. The ESP01 would blink perfectly when I manually triggered it via the browser, but the switch in OpenHAB wouldn’t respond. I double-checked my configuration, made sure the IP address was correct, and even tried adjusting the refresh rates, but nothing seemed to work. It was pretty frustrating, but I kept at it!
On the Bosch dishwasher front, I’ve been trying to set up a schedule so that it starts running automatically at midnight every night. I’ve set up a schedule through Home Connect, but the dishwasher doesn’t start on its own. I load it, press start, and if I hold the button, it runs immediately, but tapping it just pulses the light without starting. I assumed it would default to the schedule, but no luck so far. I’ve tried everything from manually starting it multiple times to checking the time zones, but it’s still not working as intended.
I decided to combine these two projects to see if I could create a smart automation. The idea is that when the dishwasher starts at midnight, it also triggers the ESP01 to start the lighthouse sequence as a visual indicator. It sounds simple, but getting both parts to work together has been quite the challenge!
After a lot of trial and error, I realized that the issue with the ESP01 might be related to how the HTTP binding was configured. I went back to the basics, reinstalled the binding, and carefully followed the configuration steps again. This time, it worked! The switch in OpenHAB now successfully controls the ESP01, and the lighthouse sequence starts and stops as expected.
As for the dishwasher, I’m still working on getting it to run automatically. I suspect it might be a timing issue or perhaps something with how the schedule is set up. I’m planning to reach out to the Bosch support community for more insights, but for now, I’m happy to have the ESP01 integration working smoothly.
This project has been a great learning experience. It taught me the importance of meticulous configuration and the value of persistence when troubleshooting. I’m looking forward to expanding on this setup and maybe even integrating more devices in the future!
If anyone has tips on getting the Bosch dishwasher to run automatically or suggestions for improving the ESP01 integration, I’d love to hear them. Thanks for reading, and happy tinkering!
