Hello everyone, I wanted to share my experience with integrating an ESPHome Bang-Bang controller into Home Assistant as a climate control system. I’ve been using this setup to maintain the temperature in an outbuilding using a gas fireplace as the heat source, and it’s been working quite well so far. However, I’m running into an issue with configuring Home Assistant to recognize the ESPHome device as a climate platform.
Here’s the relevant portion of my ESPHome configuration:
yaml
sensor:
- platform: dht
pin: 14
temperature:
name: Bunker Temperature
humidity:
update_interval: 60s
model: SI7021
switch:
- platform: gpio
pin: 12
climate:
- platform: bang_bang
name: “Bunker Thermostat”
sensor: bunker_temperature
default_target_temperature_low: 19°C
default_target_temperature_high: 21°C
away_config:
default_target_temperature_low: 8°C
default_target_temperature_high: 12°C
heat_action:- switch.turn_on: bunker_furnace
idle_action: - switch.turn_off: bunker_furnace
Currently, only the sensors and switch are detected in Home Assistant, but I’m not sure how to get the climate platform recognized. I’d love to be able to set the outbuilding to ‘away’ mode overnight, similar to how my Venstar Colortouch thermostat works. Any guidance on what to add to HA’s configuration.yaml would be greatly appreciated!
I’m really excited about the potential of this setup, and I hope to get this working smoothly. Let me know if you’ve tackled something similar or have any tips to share. Thanks in advance for your help!
