EspHome Climate Integration: A Smooth Experience with Physical Switches
Hello everyone! I wanted to share my recent experience with integrating the EspHome Climate component into my home automation setup. It’s been a fantastic journey, and I’d like to walk you through how I managed to sync my physical switch with the climate control panel in Home Assistant.
I started by setting up an ESP8266 board with a DHT22 temperature sensor and a Sonoff R2 mini switch connected to my heater. The goal was to maintain the functionality of my physical wall switch while ensuring the system updates in real-time. Initially, I faced a challenge where the switch worked perfectly but didn’t reflect its state in the Home Assistant dashboard. This was frustrating because the logs showed that the switch was detected, but the GUI remained unchanged.
After some research and trial and error, I realized that the issue was with updating the climate mode status in the component. I reached out to the community for help, and the support I received was amazing! Someone suggested modifying the firmware with a few lines of code to ensure the switch’s state was correctly reflected. Although I’m not a coding expert, I managed to tweak the configuration with some guidance, and it worked like a charm!
Here’s a quick overview of what I did:
  • Connected the physical switch to the Sonoff R2 mini’s S1/S2 inputs.
  • Configured the switch to toggle the relay controlling the heater.
  • Updated the climate component to read the switch’s state and update the GUI accordingly.
Now, when I press the physical switch, the climate control panel in Home Assistant instantly updates, showing whether the heating is on or off. This integration has made my home automation setup more intuitive and user-friendly.
I’d like to thank everyone in the community who helped me troubleshoot and find a solution. It’s experiences like these that make being part of such a supportive community truly rewarding. If anyone else is facing similar challenges, don’t hesitate to ask—there’s always someone willing to help!
Happy automating! :slight_smile:
