I’ve been experimenting with ESPHome and the ESP8266 module, and I wanted to share my journey and some tips that might help others facing similar challenges. Deep sleep mode has been a fascinating topic for me, as it promises to extend battery life while maintaining functionality. However, getting it to work seamlessly wasn’t without its hurdles.
Initially, I set up a simple project with an ESP8266 and a BME280 sensor. Without deep sleep, everything worked perfectly—sensor data was collected and sent every 10 seconds. But introducing deep sleep introduced some puzzling behavior. The device wouldn’t reconnect to WiFi after waking up from deep sleep, which was frustrating. I scoured through logs and code configurations, tweaking parameters like run_duration and sleep_duration, but the issue persisted.
After some research and trial and error, I realized the problem might lie in how the WiFi module was being reinitialized after deep sleep. I adjusted the power_save_mode settings and ensured that the WiFi initialization was properly handled in the code. Here’s a snippet of the working configuration:
yaml
wifi:
ssid: “YourNetwork”
password: “YourPassword”
power_save_mode: none
By disabling power save mode, I ensured that the WiFi module stays active and ready for quick reconnection after deep sleep. This adjustment made a significant difference. Now, the device wakes up, reconnects, and sends sensor data reliably within the configured intervals.
This experience taught me the importance of understanding how low-power modes interact with hardware components. It also highlighted the value of thorough logging and incremental testing. If you’re experimenting with deep sleep or facing similar connectivity issues, I recommend:
- Checking WiFi reinitialization settings.
- Monitoring logs for connection attempts and errors.
- Testing with shorter sleep durations initially to isolate issues.
I’m now confident in my setup and looking forward to expanding it with more sensors and functionalities. If anyone has tips or encountered similar challenges, I’d love to hear your experiences!
Happy coding and tinkering! ![]()
