ESPResense Configuration Tips and Tricks
Hello fellow Home Assistant enthusiasts! I wanted to share my recent journey with ESPResense and how I managed to get everything working smoothly. If you’re new to ESPResense or struggling with device tracking, this might be helpful for you!
My Setup
I recently set up 4 ESPResense stations to track my family’s devices. It was a bit overwhelming at first, but I managed to get through the configuration process. Here’s what I learned:
  1. MQTT Configuration
    • Make sure your MQTT broker is correctly set up. I used Mosquitto and it worked like a charm.
    • Double-check the state topics and json_attributes_topics in your configuration.yaml. They should match exactly what ESPResense sends.
  2. Device Tracking
    • The trickiest part was getting the tracked devices to show up correctly. Initially, I faced the distance: null issue, which was frustrating.
    • I realized the problem was with the topic names. ESPResense documentation suggests using the IRK in the topic, but I found that using a custom alias worked better for me.
  3. Tips for Others
    • If you’re having trouble with device tracking, verify that the MQTT topics are correctly set in both ESPResense and Home Assistant.
    • Use MQTT Explorer or another MQTT client to monitor the messages. It helps identify if the data is being sent correctly.
  4. Final Thoughts
    • ESPResense is a fantastic tool for device tracking, but it does require some patience and troubleshooting.
    • Don’t hesitate to reach out to the community if you’re stuck. We’re all here to help!
I hope this helps someone out there who’s struggling with ESPResense configuration. Happy automating! :rocket:
