Étendre le réseau Zigbee
Bonjour
Est-ce que le hub e1 ou le smart hub 100 peuvent étendre le zigbee et sinon quel produit peut le faire.
Hi there and welcome to the forum.No the hubs doesn’t act as zigbee extenders as each hub creates his own zigbee mesh so in order to make an zigbee mesh you need to have zigbee extenders like bulbs and smart plugs connected to the same hub.
Merci je vais essayer
Your welcome.ether way smart plugs,lights strips and bulbs can make an zigbee mesh if they all are connected to the same hub the only thing you need is to place them well so the zigbee mesh be strong.
