Hey everyone! I’m super excited to share some fantastic news about a new integration that’s just been released for Hubitat. The LG webOS TV driver is now available, and it’s packed with features that will take your smart home experience to the next level! ![]()
This driver allows you to seamlessly control your LG webOS TV directly from your Hubitat system. Whether you want to turn your TV on or off, adjust the volume, change the input source, or even launch your favorite apps, this integration makes it all possible with just a few taps. Plus, it supports Wake-on-LAN (WOL), which means you can power up your TV from anywhere, without needing any extra apps or drivers. How cool is that? ![]()
Key Features:
- Switch Control: Turn your TV on or off effortlessly.
- Volume Adjustment: Mute or adjust the volume to your perfect level.
- Input Source: Quickly switch between different inputs like HDMI, USB, or your favorite streaming service.
- App Launcher: Launch apps directly from your Hubitat dashboard.
- Virtual Device Integration: The TV appears as a virtual device in your Hubitat setup, making it easy to include in automations.
Installation Made Simple:
- Enable External Control on Your TV: Head to your TV’s settings and make sure external device control is enabled for both WiFi and mobile connections.
- Set Up Static IP: Ensure your TV has a static IP address for consistent connectivity.
- Install the Driver: Copy the driver code into your Hubitat dashboard and follow the setup instructions to add your TV as a virtual device.
- Pairing: After adding the device, you’ll get a prompt on your TV asking for permission to connect. Once paired, you’re all set!
This integration is a game-changer for LG webOS TV owners looking to enhance their smart home setup. It’s user-friendly, feature-rich, and eliminates the need for extra apps or complicated configurations. If you’re a Hubitat user with an LG TV, I highly recommend giving this driver a try! ![]()
Let me know if you’ve tried it out and what you think! Happy automating! ![]()
