【Exclusive Trial】Aqara Radiator Thermostat W600 – Be the First to Try
Hi, I want to paticipate.
I’m from France and compatibility is OK.
Hi!
Would love to test the Thermostat. I refrained from purchasing the previous ones due to screen position.
a. Poland
b. I do have compatible setup ( M28 x 1.5mm )
I am interested in the trial
a. Greece
b. I confirm that my setup supports the Radiator Thermostat W600
I am from the Czech Republic and the device is fully compatible with the radiators I use. At the moment, I am already using 10 pieces of E1 from Aqara. Robert
am from Germany and have the necessary connections to the heating. I also have the W100 and the T1 temperature and humidity sensors, and experience with the E1 thermostats and Tado X. I’d like to test the new thermostat.
I am from Germany too and I can confirm that the thermostat should fit. I’d like to test the new device
Hi I am interested in Testing the new radiator . I am from Germany.
Hi, yes please put me down for testing this new Radiator Thermostat W600
a. I am in the United Kingdom
b. Yes, my setup is compatible
Hi From UK and have Compatible Radiators and Aqara Temp sensors already want to be part of the Trial
I would love to test the W600!
Country: The Netherlands
I confirm that my setup supports the radiator thermostat.
Bonjour,
Je souhaite participer au test de cette nouvelle tête de chauffage connectée ! Ayant déjà tous mes radiateurs avec la tête E1 aqara , je serais ravi de voir l’évolution et d’en équiper tout mon domicile ! Je suis de France et mon radiateur est bien compatible
I would be delighted to try this thermostat. :slight_smile:
Hi, id like to join the trial.
I’m from Ireland and I confirm my setup is compatible. I would like to join the trail.
I’m interested
Country: UK
Setup supports valves
a. Italy
b. Confirm the compatibility (now I already have 7 thermostat valves E1).
A) Netherlands
B) compatible
a. Romania
b. my setup setup supports the Radiator Thermostat W600: compatible with valves M28×1.5mm
Hi from France. My radiators are compatible. I’m currently using EVE on radiators, the one device I don’t have Aqara on. Let’s change this misunderstanding )))
I’m from Italy and the Thermostat is compatible with my Radiator. Id love to Test this product as well :slight_smile:
