Expanding network range
Having issues keeping temperarure sensors from loosing their connexion to a M100 hub.
I don’t want to add a network by adding another hub, but simply to expand the range.
Many thanks
I’m having the same problem with my Temperature and Humidity sensor. It continually loses contact with my M3 hub. I’ve even moved my hub to within 10-15 feet of the sensor with no luck.
Adding another hub doesn’t extend the network, each hub creates its own network. And it means that simply adding a hub won’t extend the range unless you rebind some of the devices to the new hub.
If you use Zigbee, you can extend the range by adding devices with neutral. This includes lightbulbs, smart plugs, smart switches (with neutral) or relays.
