Experiencing Residual Voltage with Leviton Z-Wave Receptacles
Hi everyone, I’ve been experimenting with smart home technology lately and decided to install some Z-Wave receptacles in my home. I purchased the Leviton DZR15-1LZ model, and overall, it’s been a great addition. However, I’ve noticed an issue that I’m hoping to resolve before making any further purchases.
The problem I’m encountering is related to residual voltage when the outlet is turned off. I tested it with a multimeter and found that when the outlet is ON, it reads 120V as expected. But when I turn it OFF, it still shows 90V. This residual voltage is causing some LED lamps I’ve plugged in to remain faintly lit instead of completely turning off. It’s a bit frustrating because I expected a cleaner cutoff.
I’ve seen similar behavior with some plug-in modules, so I’m wondering if this is a common issue with Z-Wave receptacles. Specifically, I’m interested in the GE 12721 model. Before I place an order, I’d like to confirm whether this model completely cuts off the power, resulting in 0V when measured with a multimeter.
Has anyone else experienced this with their smart outlets? If so, did you find a solution or a workaround? I’d appreciate any insights or recommendations you might have. Thanks in advance for your help!
