Hello Community,
I’ve been diving into the world of Blockly scripts lately, and I must say, it’s been an exciting journey! I’m currently working on a project where I need to adjust the value of a smart home item over time—think of it like gradually increasing the brightness of a light or slowly lowering the volume of a speaker. The goal is to make this adjustment smooth and seamless, even when applied to multiple items simultaneously.
Initially, I thought this would be straightforward. I envisioned creating a generic script that could handle different items without interfering with each other. However, as I started coding, I ran into some hurdles. The most puzzling issue was encountering a ReferenceError: itemName is not defined error in the console logs. This was perplexing because I had set up the context attributes and even included logging messages to ensure everything was in place.
To troubleshoot, I reviewed my script meticulously. I realized that the variables inside the timer body weren’t retaining their values as expected, even for the first execution. I experimented with adjusting the initial delay and renaming the timer, but the problem persisted. It was a bit frustrating, but I knew I was on the right track.
Here’s a snippet of my Blockly-generated code for reference:
javascript
var startValue, endValue, intervalInS, itemName, updateIntervalInS, delta, stepCount, stepSize, counter, currentValue;
// … rest of the code
After some research and trial and error, I discovered that the issue might be related to how variables are scoped within the timer function. I started exploring ways to ensure that all necessary variables are correctly passed into the timer’s execution context. This led me to consider restructuring the script to better encapsulate the variables and their lifecycle within the timer.
I’d love to hear from anyone who has successfully implemented similar time-based adjustments using Blockly scripts. What strategies did you employ to maintain variable scope and ensure smooth execution? Any insights or tips would be invaluable as I refine this script.
Looking forward to your feedback and experiences!
Cheers,
Clemens
