Exploring Bluetooth Data Transmission with NRF5340
I recently embarked on a project to test the Bluetooth functionality of the NRF5340 chip using the peripheral_uart example from the Nordic Semiconductor samples. My goal was to send a data packet from the chip to a mobile phone via Bluetooth and verify the integrity of the received data. Here’s what I did and what I encountered:
  1. Setup and Configuration: I started by setting up the example project located in nrf/samples/bluetooth/peripheral_uart. This project is designed for Bluetooth data transparent transmission, which seemed perfect for my needs.
  2. Data Packet Creation: I created a simple data packet and instructed the Bluetooth module to send it. The data packet was straightforward, and I included a timestamp to track transmission times.
  3. Timer Initialization: To ensure periodic data transmission, I added a timer initialization in the main function. Here’s the code snippet I included:
    c
    k_timer_init(&adc_timer, adc_timer_handler, NULL);
    // Initialization: handler, expiration callback, stop callback (NULL)
k_timer_start(&adc_timer, K_MSEC(100), K_MSEC(100));
// Start immediately with a 100ms period.
This was meant to trigger the data transmission every 100 milliseconds.
  1. Testing and Challenges: After setting up everything, I connected the NRF5340 chip to my development environment and initiated the Bluetooth pairing process with my mobile phone. The connection was successful, but I encountered an issue where the mobile phone did not receive the data packets. This was perplexing because the connection seemed stable.
  2. Troubleshooting: To diagnose the problem, I checked the following:
  • Bluetooth Settings: Ensured that the mobile phone’s Bluetooth settings were correctly configured to receive data.
  • Code Review: Double-checked the code for any syntax errors or logical issues. The timer and data transmission logic seemed correct.
  • Hardware Connections: Verified that all hardware connections were secure and that the NRF5340 chip was powered correctly.
  1. Seeking Solutions: Despite these checks, the issue persisted. I decided to consult the Nordic Semiconductor community and forums for assistance. Posting my issue here was a crucial step, as I believed the collective knowledge of the community could shed light on the problem.
  2. Lessons Learned: This experience taught me the importance of thorough testing and the value of community support in troubleshooting complex issues. It also highlighted the need for meticulous debugging, especially when dealing with low-level hardware interactions.
I’m hopeful that with the help of the community, I can resolve this issue and successfully implement the Bluetooth data transmission functionality. If anyone has encountered a similar problem or has insights into potential solutions, I would greatly appreciate your input!
Looking forward to your thoughts and suggestions.
