Hi everyone, I’ve been diving into some advanced functionality in Home Assistant and wanted to share my experience and a question I have. I’m using Node-RED for my automation setup, but I suspect this question might be relevant to others as well.
I’ve been experimenting with service calls to set multiple parameters at once. For example, I tried setting parameters 16 and 23 simultaneously, but I ran into an error stating that the parameter was duplicated. My initial assumption is that bulk setting multiple parameters in a single call isn’t supported, but I wanted to confirm this with the community.
Has anyone else encountered this or found a workaround? I’d love to hear if there’s a way to achieve this without making multiple service calls. Efficiency is key in my setup, and being able to update multiple parameters in one go would be a huge time-saver.
On a positive note, I’ve been impressed with how Home Assistant handles most of my automation needs. It’s a pleasure to work with such a flexible and powerful platform. I’m hopeful that with the right approach, I can find a solution to this bulk parameter update challenge.
Looking forward to your insights and experiences!
