Hello everyone! I’ve been diving into the world of custom scripts to optimize my smart home setup, and I wanted to share my journey and some insights with you. While I’ve found text editors to be my go-to for script writing, I’ve noticed that the WebUI experience can sometimes be a bit underwhelming, especially when dealing with advanced code. The way it flattens code into lines with “\n” is a bit frustrating, and it happens even when I’m just browsing through different scripts. I’m curious to know how others handle this—do you have any tips or alternative methods that make working with scripts in the WebUI more seamless?
On another note, I’ve been experimenting with automations triggered by power state changes, particularly with my AC unit. My wife wanted a system that turns the AC on when the room temperature exceeds 73 degrees and turns it off once it cools down to 69. I set up a basic IR transmitter with a temp sensor on a Wemos D1, and while it works to some extent, it’s got a few quirks. The main issue is that once the room cools below 69, the AC turns off, but it kicks back on again as soon as it reaches 69. It’s like a endless loop! I’ve considered adding a delay to prevent this oscillation, but I’m not entirely sure how to implement that effectively. Any suggestions or experiences you’ve had with similar setups would be invaluable!
Another thing I’ve been pondering is the aesthetic aspect of smart home integration. While functionality is key, having everything look cohesive and polished is just as important. I’ve been researching different ways to streamline my setup and make it visually appealing. If anyone has tips or resources on achieving that perfect balance between form and function, I’d love to hear about them!
Lastly, I’ve encountered some challenges with the Inovelli fan/light switch. It controls both the fan and lights, but I’ve noticed some errors in the log file that I’m not quite sure how to address. The logs show a NumberFormatException, which seems to occur periodically. I’m using the HE driver, and I’m wondering if updating anything or adjusting the configuration might help resolve this issue. Has anyone else experienced something similar, or do you have any troubleshooting steps that could guide me?
Overall, this journey into custom scripts and automation has been both rewarding and challenging. I’m excited to continue exploring and refining my setup, and I’m eager to learn from the experiences of others in the community. Let’s keep the conversation going and share our tips, tricks, and successes!
